Home › Forum › Ask A Member › Boat trailer wheel
  • #285554
    tinkerman
      Does anyone know of a source or have an extra wheel for the old 1-1/16″ spindle with the single castle nut holding it on? I’m trying to get my old Cherokee boat and trailer road ready, but I’m in need of a wheel in order to have a spare. I thought about changing out to the hubs with lugs but it’s a short spindle and I’m not seeing a kit for those. And no luck finding a wheel. I see some for log splitters but they are 1″ spindle size. Any help would be appreciated
      It's a jungle out there.
      #285612
      JOSEPH BRINCAT
        I suspect that you will have a problem with this one.  I had a small boat trailer that had the 1″ hub-less wheels. I bought the “log Splitter” spare wheel assembly and discovered that the bearing spacing was different. After de-mounting the tire, had a lathe job to re-bore to the correct spacing.  And another recent encounter with an old trailer with rusted out no-hub wheels ended up reworking for 4 bolt hubs and new wheels.  Even that job required making new longer sleeves for the seals, shortening the spindles about 1/2″ and drilling new cotter pin holes.
        #285686
          Wow Joe,
          That’s much work & determination!!
          #285755
          MIKE SIMS
            PM sent
            #285757
            scubapop
              I’ve located some real wacko trailer parts from
              Expediter Trailer Parts
              Phone:(800) 330-1800
              Give them a try
              #285796
              William Jatzek
                Why don’t you just buy a new modern axle and hub assembly and get rid of your obsolete  axle? This way everything is available.
                #285995
                MIKE SIMS
                  Is this what you are looking for?
                  DSCN2624
                  DSCN2625
                  #286004
                  JOSEPH BRINCAT
                    That is what the OP was asking about, but from my expierence with these, one will need to know a few details, like…
                    • tire, wheel size
                    • axle diameter
                    • spacing of the bearings ( distance from cone to cone)
                    These hubless wheels are not all the same
