Home › Forum › Ask A Member › boat speed seems too slow
- This topic has 7 replies, 6 voices, and was last updated 11 years, 5 months ago by
legendre.
May 24, 2015 at 5:00 pm #1589
I recently purchased two motors to put on my 11 ft vee bottom.the first I tried was a 1975 wards sea king 3.5hp that needed to be slightly choked to keep running.It struggled to make it to 4mph .I switched over to the 1985 evenrude 4hp and touched 6mph twice for a second or two but pretty much kept at 5mph.while using one,the other was near the front seat and not causing drag.The four hp was smooth as a kitten.the wards motor ia a two blade prop and the rude is a three blade. Am I expecting too much?
May 24, 2015 at 8:02 pm #16794Probably
May 24, 2015 at 11:15 pm #16799Just for grins lock your steering good and tight and move to the front seat for a few seconds. Watch what happens.
Anyway…..Hard for an 11′ boat to run above displacement speed with that hp.
May 24, 2015 at 11:33 pm #16801quote bigbelliedoldman:(…) a 1975 wards sea king 3.5hp that needed to be slightly choked to keep runningPlugged-up low speed circuit, or possibly bad crank seals? If it needs choke, that almost always indicates it’s getting too much air, somewhere..
May 25, 2015 at 1:16 pm #16831pappy,I.m hoping that moving up in the boat was a joke,but then i could try it with an extention on the steering handle.The 3.5 hp sea king was acting like it was running out of fuel after about 30 seconds at full throttle,but slowing down wouldnt keep it running till slightly choked.if i ran just slightly choked it would do the same(want to stall)until i throttled down.i was thinking it was a fuel delivery problem.I’ll try some seafoam in the tank.it ran smooth in a barrel two months ago.
May 25, 2015 at 1:52 pm #16834I have a 10 ft Grumman V-bottom and always use a tiller extension. I put a board between the middle and rear seat so i can sit halfway between them and even a 3.5 hp will get me up on plane. If I use a 5 HP, the tank goes forward of the middle seat. I get about 16 mph on average.
May 26, 2015 at 12:59 am #16888I’ve done the move to the front of the boat trick. Just tighten the steering up and find a good straightaway. It got me up to 16 mph with my 56 Johnson 5.5hp. It’s pretty fun.
May 26, 2015 at 1:20 am #16891quote bigbelliedoldman:pappy,I.m hoping that moving up in the boat was a joke.No joke at all.. center-of-mass is quite important.
