Home › Forum › Ask A Member › Blue Ribbon points
  • #5266
    bob54
      Well I took the points apart to clean them and now I am not sure I have them back together correctly. Does anyone have an exploded view of the points I can look at? I know,,should have taken a photo or drawn a diagram. And how do you connect the lug wire to the coil, my plug wire seems to be aluminum and won’t take solder.
      https://SecretPrivat.com - - No Selfie - Anonymous Sex Dating -
      #44107
        It could be high voltage wire for neon signs. They use stainless steel. Aluminum wire has caused many a house fire do to corrosion and the difficulty of attaching it to anything.
        I have not been able to find a picture of a Champion magneto, Sorry . . . . 😳
        #44108
        bob54
          Thanks Gary,,,should I change the plug wire to a copper one?
          #44114
            Absolutely, !t should be a solid copper multi-stranded wire like Packard 440.
            #44118
              They didn’t solder the wire to the Bendix-Scintilla coils. Tin the wire with solder, then simply stick it through the hole in the lug and twist it around the lug one time.
              #44124
              bob54
                Thanks guys for the help. I did find a photo of the points so hopefully I’ll be good to go
                #44563
                bob54
                  IT’s ALIVE!!!!!
                  Well it’s all back together and running. Still some fine tuning to do on the carb. But I have water peeing from the bottom hex head bolt. good strong stream, (Like I did when I was young) do I just need to put sealer on the threads of the bolt or do I have a major problem?
