Home › Forum › Ask A Member › Blowing Bubbles Below The Powerhead? ’49 Sea King
- This topic has 3 replies, 3 voices, and was last updated 3 years, 1 month ago by
John Gragg.
October 3, 2023 at 11:51 pm #281303
Short video of bubbles blowing out from below the powerhead. Looks like the top of the driveshaft housing?
Anything to be concerned about?
https://youtube.com/shorts/qTo0e9t7uTI?si=s7Bz2kVMXz7b2634
Thanks All,
Best Regards,
John Gragg
RIverside, CAJust starting in the hobby, please be patient.
48 Sea King 5hp GG9014A. Sold
49 Sea King 5hp GG9014A
48 Johnson TD20. Sold
49 Johnson TD20. Sold
54 Johnson QD15. Sold
55 Johnson CD12. Sold
57 Johnson RJE-19M
57 Johnson RDE-19October 4, 2023 at 11:12 am #281313not to many options.
- crack
- loose bolts
- bad gasket
October 4, 2023 at 5:03 pm #281319There appears to be a channel leading to that hole. Can’t say that I remember its purpose. #16 is a seal to keep water & exhaust from blowing out but that doesn’t seem to be where your bubbles are coming from.
EDIT: the channel seems to be the cooling water exit(??) But I still don’t understand the bubbles hole. Or is there really a hole? Perhaps I’m seeing a hole that isn’t there. If no hole, probably simply a leaking gasket
October 4, 2023 at 9:05 pm #281340There appears to be a channel leading to that hole. Can’t say that I remember its purpose. #16 is a seal to keep water & exhaust from blowing out but that doesn’t seem to be where your bubbles are coming from.
Thanks Frank. I already have the gasket, so when I pull it all apart to clean/possibly add a little paint I can replace it then and evaluate if there is further concern.
Just wanted to check if it was a 911 on not running it…
THanks!
Best Regards,
John Gragg
57 Johnson RJE-19M
57 Johnson RDE-19 -
