Home › Forum › Ask A Member › Blind Bearing Puller
- This topic has 7 replies, 6 voices, and was last updated 11 years, 4 months ago by
ERROL STILLINGS.
June 30, 2015 at 10:48 pm #1903
In the Pochefamily.org/outboard/carburetorservicing site, David Poche mentions a blind bearing puller
for extracting brass cylinders from primer in H & T Johnson motors. I haven’t found a way to send
question to David Poche, but have great difficulty pulling these brass cylinders. He says they
are expensive but work well and I would like to explore. Does anyone know where I could
check into finding one of these? There is a photo in his writeup.June 30, 2015 at 11:18 pm #19251I don’t know about Dave’s blind bearing puller, but one can usually pull a blind brass or bronze bushing by screwing in a suitably sized tap and pulling that , or then insert a stud and pull on that. Of course you then must replace the "screwed- up " bushing.
July 1, 2015 at 1:10 am #19263A blind bearing puller passes though the ID of the bearing, with a pair (or trio) of wedge-shaped fingers that are expanded, wedging the fingers between the bearing’s inner race and the bottom of the bore. Then either a tension screw or slide hammer is used to extract the bearing.
I believe there is also a type which expands directly within the ID and grips the sides.. ultimately, it’s all a matter of obtaining proper purchase on the part to be removed, and these devices have their limits.
ETA: Also, this method tends to damage or ruin the bearing, as it pulls on the ID which is never desirable. In the case of the thin-wall brass insert in the Johnson carbs, there’s a good chance it will slightly distort but not totally wreck the part. All depends on how much force is required, obviously.
July 1, 2015 at 1:52 am #19269Can you use the heavy grease and hammer method like we do removing needle bearings from K Merc gear boxes?
JW in Dixie
July 1, 2015 at 4:24 am #19277The’re on sale right now at Princess Auto.
http://www.princessauto.com/en/detail/b … -p8104036e
July 1, 2015 at 10:20 am #19280That looks like a worthy tool for a number of jobs. Like pulling the drive shaft bearing out of a Big Twin.
July 1, 2015 at 3:56 pm #19296Amazon.ca has them to.
http://www.amazon.ca/Bearing-Internal-E … puller+setJuly 2, 2015 at 2:34 am #19325Thank you Mumbles. I have tried Princess Auto – for the special price thru July 5th – but they are apparently closed
today. I will go to Amazon. Everyones help is appreciated. I hope this Blind Bearing Puller works. -
