Home › Forum › Ask A Member › Blast media
  • #265019
    Samuel Phelps
      What are you guys using for media if you do blast for paint prep . I have like a medium coal slag I got from Northern Tool . It works but it takes a lot of sanding afterwards ..
      #265020
      JZago
        There are many choices of blasting media out there ranging from aluminum oxide to walnut shells.  I have found that aluminum oxide is the quickest and most effective blasting media.  However, there are a number of down sides to aluminum oxide.  It wears blasting nozzles and vacuum motors faster than other media.  It also leaves a rougher surface than other media.  The other media I prefer is glass beads.  It works well on aluminum parts and leaves a smooth finish.
        #265023
          I have been using glass bead media with good results.  Others swear by walnut shell media.
          1982 Evinrude 25hp
          #265055
          johnny
            I use plastic beads from Tip tool on all my aluminum blasting with excellent results.
            #265057
            Samuel Phelps
              I’ll have to look that up ..
