Home › Forum › Ask A Member › best practice for cleaning mixture needle packing nut material
- This topic has 5 replies, 3 voices, and was last updated 1 year, 1 month ago by
Bob Wight.
September 22, 2025 at 2:51 pm #300056
I’m struggling with black stubborn packing nut material in a carb I’m rebuilding. Trying to mechanically remove the old packing
and not having much luck. Then I realized there must be some experienced lads out there that might share a tried and true method
or particular solvent that dissolves these things. I look forward to your comments…..Guy Schmidt
September 22, 2025 at 3:15 pm #300057When rebuilding my carbs, I usually either soak them in a gallon bucket of Berryman’s Chem-Dip carb cleaner or soak them in hot water in a kitchen crock-pot. Either method seems to soften the packing material so you can get them out with a small pick tool.
"Every time you remove a broken or seized bolt an angel gets his wings."2 users thanked author for this post.
September 23, 2025 at 8:10 am #300073Very interesting topic indeed. I oftentimes skip trying to pull out the old packing for fear of introducing debris into the mixing pocket, usually just add fresh packing over the old stuff… Will definitely try Bob’s suggestion during my next hot ultrasonic cleaning though
September 23, 2025 at 9:36 am #300076Great Bob, I’m going to try one or both of those techniques today!
September 23, 2025 at 9:58 am #300077Hey Fleetwin, thank you also. Since my carb is off the engine I’m going with replacement. But, under other
situations I might try your suggestion.
September 23, 2025 at 10:20 am #300080Very interesting topic indeed. I oftentimes skip trying to pull out the old packing for fear of introducing debris into the mixing pocket, usually just add fresh packing over the old stuff… Will definitely try Bob’s suggestion during my next hot ultrasonic cleaning though
A hot ultrasonic soak would likely be the best solution. I don’t have an ultrasonic so my hot crock-pot method was my alternative!
"Every time you remove a broken or seized bolt an angel gets his wings." -
