Home › Forum › Ask A Member › Bendix Scintilla coil
- This topic has 10 replies, 6 voices, and was last updated 3 years, 7 months ago by
Tubs.
March 29, 2022 at 8:05 am #257093
Was able to obtain a replacement coil for my Champion Blue Ribbon 1J project. Of course the replacement coil is configured differently than the original. Original had a wire out each end and the replacement has both wires out one end.
Being new to all this, my working theory is that the 2 wires, one black and one red, constitute the primary; and the sparkplug connection ring is one side of the secondary.
My question is how to test it. I have two meters both only have a 2K ohm setting, no 1K. I get that I connect black to black and red to red across the primary to test it. How do I connect to test the secondary? Also, I can find no reference for expected values for this Bendix Scintilla coil.
I get numbers on the primary, bit nothing on the secondary.
Sorry, picture files are too large to send
March 29, 2022 at 8:10 am #257094March 29, 2022 at 8:38 am #257097To test the secondary, meter across the high tension terminal and either of the primary wires. But if your meter only goes up to 2K ohms, you may not get a reading. Never heard of one like that.
T
March 29, 2022 at 8:59 am #257100Tom,
Sorry for the confusion. My meter has a full range of settings. It just doesn’t have a 1K setting. See picture.
March 29, 2022 at 9:02 am #257101March 29, 2022 at 9:23 am #257103Tom,
Set for 20K and got a reading of 3.8 on the secondary.
Thanks for stearing me in the right direction. Onward to getting spark. Thanks again. AOMCI is awesome.
Ron
March 29, 2022 at 11:42 am #257125Black is probably a common ground for both circuits and red to the points.
March 30, 2022 at 3:08 pm #257185Mumbles. Thanks. Sounds right.
March 16, 2023 at 3:46 pm #273986Hi ,Im in desparate need of 399-756 bendix coils. Is someone making them still???
call me 503-365-0777 pacific time Thanks
March 16, 2023 at 8:06 pm #274015Various posts on the site regarding Scintilla coils
https://www.aomci.org/forums/topic/bendix-scintilla-coil-numbers/
