Home › Forum › Ask A Member › bearings
  • #270008
    David C
      Got my 1942 evinrude 2hp 4364 elto started today thanks to help from AOMC only to discover the motor will run for 4 seconds a set up.After taking head off and checking inside it looks like way to much play in rod bearings.Could this cause motor to stop in a certain position ?Dont see any damage caused by this issue as ivetried several times and same thing happens.It will rotate out of this position and restart for a few seconds.Can the bearings be replaced if this is my issue?Hate to give up.Thanks DaveR
      #270024
        From your description I would first suspect a fuel issue.
        A partial blockage somewhere which is letting a small
        amount of fuel get into the cylinder but when it is gone
        the motor stops running. Probably should start with the
        gas cap. Is the vent open? Is the vent hole plugged?
        Check for a filter in the gas tank, is the petcock open or
        plugged, possible blockage in the fuel line from the tank
        to the carburetor, check the filter in the carburetor,
        blockage in the carburetor, is the float bowel filling with
        fuel, is the mixture screw open far enough. As far as the
        connecting rod issue and the motor stopping in a certain
        position, this could indicate some binding somewhere.
        If you don’t have a fuel issue you would need to provide
        a video of what your experiencing before I would offer
        an opinion as to what could be going on.
