Home › Forum › Ask A Member › Bearing Help
  • #1210
      All the roller / needle bearings I need for my Firestone
      Lower Unit have a "X" after the number.
      What does X designate?
      For Example, I have these Torrington Bearings I need to replace….
      B-108 X
      BH-812 X
      I’ve found bearings online, but none with the X suffix.
      Thanks, Clueless
      foot_doctor
        The X suffix denotes EXTRA PRECISION. The B-108X is now GB108. I have not had any experience with the BH-812X, but I suspect that a GBH812 is not available. The origials were made by Torrington, and the company is now owned by KOYO. You may not use a B108 to replace a GB108. The B108 has a slightly larger diameter, and when pressed into the bore, it will shrink too small to accomodate the shaft it supports. The GB-108 is for a 5/8" shaft and is 1/2 inch long. The BH812 is for a 1/2" shaft and is 3/4" long. If I can locate my old Torrington catalog, I’ll try to find the specs for your bearings and post them here. R.T.
        #13978
          Much appreciated Doc!
          P.S.- Found the bearings on Amazon, Thanks!
            Received my new GB prefix Koyo needle bearings today to replace my
            old Torrington bearings with the X suffix as suggested.
            The new bearings fit on the shafts okay, but I’m able to slide them
            in the bores by hand. Presume I should have had to "tap" them in?
            The old ones sure had to be tapped out. I put some locktite on the
            bearing shells and installed them for lack of a better idea.
            Will this work?
              Try and find the Torrington or Koyo PDF catalogue on line to check the sizing of the new bearings. They should be a press fit and if they fell in the hole, they might be metric.
              #14611
                Worth a try, thanks Mumbles.
                  I have been studying up on the needed needle bearings for the Firestone.
                  Trying to replace the old Torrington bearings,
                  B-108X
                  BH-812X
                  The GB-108 and GBH-812 Koyo bearings I was steered to, are .002 to .003 too
                  small in the OD, and too loose on the shafts as well.
                  Never did find out for sure what the "X" suffix meant 65 years ago, but
                  evidently not "precision ground" as the G prefix series Koyo bearings.
                  Did find a handy Torrington Prefix and Suffix chart at……
                  http://www.ahrinternational.com/TORRING … ture.shtml
                  Interesting enough, they don’t have a "X" suffix in the list.
                  Some of the data says…..
                  G = Precision Ground
                  B = Regular Series, Inch Dimension
                  BH = Large Roller Series, Inch Dimension
                  From what I’m understanding, "Precision Ground" means your bearings
                  are going to have a larger ID, and smaller OD.
                  Interesting also, Amazon gives the same dimensions for Regular
                  and Precision ground bearings 🙁
                  I can see wanting the needles precision ground for hi rev shafts, but
                  couldn’t they make them so they’re standard size after they’re ground?
                  And why would the shell have to end up under size?
                  Tried looking on the KOYO site for actual bearing dimensions, found a
                  large PDF file, but my browser didn’t like it, and rolled over and died.
                  Think I’m going to order the standard bearings and hope for the best,
                  and try to sell the G series that are too loose.
                  Live and Learn.
                    For the next person replacing their Torrington bearings with a "X" suffix,
                    I got a reply and figured out why my GB-108 Koyo bearing did not fit…..
                    The B-108X is the old call-out. New part number is B-108 and we have stock @ $6.78.
                    X does not mean extra precision which is why your GB-108’s were loose in the housing and shaft. You’ll be fine with the B-108.
                    Thanks,
                    Randy Faber
                    Impact Bearing
                    chinewalker
                      Hmmm. So why did the X and GB series apparently interchange with my KF7? See my previous thread here. I had actually tried the B-series bearing first, and it was too tight. The GB series bearing worked like a charm…
                      viewtopic.php?t=237
                      #14889
                        Yeah, I read that one before and left me confused as well.
                        Will report back when I get the next batch of bearings!
