Home › Forum › Ask A Member › Battery powered ignition
  • This topic has 5 replies, 2 voices, and was last updated 3 years ago by Tubs.
  • #281643
    Jeff Heise
      Trying to test for spark    can i use my standard spark tester to check it?        when i had battery hooked up wire coming from points was pretty warm      is that normal?
      #281644
        Not knowing what your using, you should be
        able to use most spark testers.
        Not knowing what ignition your working on,
        or the size of your battery, I would say that
        just testing for spark shouldn’t produce any
        heat in the wires unless you using a high
        amperage battery with an under sized wire.
        I would suspect you have a short which may
        be from the points being closed all the time.
        Need much more information than you have
        provided.
        #281646
        Jeff Heise
          using a 6volt battery   which was suggested by another member       i’ll check the points one more time     tried posting pics once but were too large
          #281648
            This discussion board isn’t very user friendly when it comes to
            posting pictures.
            I’m going to assume your learning about one of the Super Eltos.
            If that is the case watch my 2 videos.
            They will give you some idea of how this ignition functions.
            https://youtu.be/zLS6IglCy9k?si=-RvjkZ_QKbDLFio2
            and
            https://youtu.be/fSqQE4CWe34?si=LQ6PgP6GDF3mBLdb
            #281706
            Jeff Heise
              That helps tremendously      didn;t realize there was so little movement
              #281707
                They are a different animal for sure but once
                you understand them they work great.
