Home › Forum › Ask A Member › Battery cable gauge
Viewing 10 posts - 11 through 20 (of 23 total)
  • #52703
    olcah
      Jeff, How many starts would you guess a motorcycle or garden tractor would do? I have a 56 Johnson 30 HP and as you know mid 50s motors have a pull start backup anyway. My boat is a 12Ft Crestliner Commander and there is not muCh space for battery in the back of that boat along with gas tank and control cables. Smaller battery is easier to hold down too.
      Thank you.
      #52705
        I found the cheapest source at a local automotive electrical starter/alternator overhaul shop. They sell #4 red and black welding cable by the foot and even install the ends by first crimping then soldering and finally shrink tubing the joint. the same as factory built cables. Welding cable is super flexible with a tough covering.
        #52706
        wiscoboater
          Thank you Jeff Register,
          I should be more clear with the boat and my layout. Due to space limitations and weight distribution/balance of the boat the battery must go in the front under the bow. The cables I was asking about would then run to the back of the boat and into the motor hood. To route them along the side up under the gunnel so they are hidden is why I end up with 11′ cables. The motor has no charging system, so the battery will need to be charged manualy from time to time. The battery it’s self is a lawn tractor battery with 300 cold cranking amps. A second set of 8 gauge cables will also come off the battery and travel the 2 feet to the bus bar and fuse block behind the dash to power LED nav lights, electric choke and the fuel gauge. I have 2 small LED lights mounted in the front and rear as well to provide lighting for the motor area and under dash area if I should at some time need to fix something in the dark out on the lake.
          I bought and ran the cables yesterday. I used the Marine Cable from my local boating supply house. 6 to the motor and 8 to the accessories. The boat is a little wood race boat design, but it will just be used by my Son and myself to blast around the lake in. No competition use.
          Jeff
          #52709
            got pic’s of the boat??
            #52713
            wiscoboater
              It’s in the current projects section. It’s titled ‘A gift for my Son"
              #52719
              oldguy
                Jeff;
                Lots of good ideas here, and here might be another one..Would a set of 4 gauge automotive "jumper cables" do the trick? They come 12 feet long, just change out the terminals, and you may be good to go..Just a thought..
                #52740
                wyo307
                  Just wanted everyones thoughts on a related subject here. How does everyone feel about using the tinned marine grade wire vs standard automotive wire? I know the marine grade will be more expensive but it should also last longer.
                  #52747
                  Pete
                    Here is DC voltage drop calculator just need to know start volts, amp draw, cable length and gauge
                    https://www.supercircuits.com/resources … calculator
                    #52749
                    Tom
                      Interesting calculator… try it with 3 gauge wire and see if the results make sense…
                      T
                      #52753
                        quote Wyo307:
                        The tinned wire is designed for marine use and while not 100% perfect, it will keep corrosion down to a minimum, especially when Liquid Tape is applied to the connections. Automotive wire will corrode around dampness and shouldn’t be used in a boat. It belongs in a vehicles dashboard, not a boats. As for the added cost, it all boils down to the ‘You can pay now, or you can pay later‘ thing. The choice is yours.
