Home › Forum › Ask A Member › Batteries for RBM Buzz Coils
  • This topic has 9 replies, 5 voices, and was last updated 8 years ago by Tubs.
  • #11703
      Trying to determine a reliable, low cost, small stature battery and
      and charging system to running a buzz coil on my Wisconsin RBM.
      Would this 6 volt, 4.5 amp, gel cell battery be up to the task?
      https://www.ebay.com/itm/Wildgame-Innov … 1598035883
      Chargers for this battery are readily available and only $10 to $15 bucks.
      I found some data (below) on a forum saying buzz coils draw about 2 amps.
      I’m unsure about battery ratings, amps vs. amp hours, etc.
      Thanks for any insight.
      Gel cell battery
      It depends on the load and size of the battery. How is ignition supplied? Auto coil, ford T coil, other vibratory coil? A T coil or other vibratory coil draws about 2 amps or so. An auto coil can draw as much as 10 amps! If you use a 6 amp or more Gel Cell, you probably can run a couple of days on one charge, if you do not run all day, continuously.
      WAYNE
        I use the same battery for my ELTOs. It will be plenty enough for you.
        Wayne
        Upper Canada Chapter
        uccaomci.com
        #85106
          quote wbeaton:
          Good to know, Thanks!
            #85123
              Wow, that is quite a price difference!
              PM T2
                I decided to quit screwing around with these little batteries. Now, I use a full-sized 6-volt car battery for my rowboat motors and Elto’s, there’s never any doubt when I go to the ramp that I’ve got enough juice to get the job done, and I don’t really care how much it weighs either.
                Best,
                PM T2
                #85127
                  #85140
                    I have had many years of trouble free running using a 6V 12AH rechargeable battery.
                    With all the hours I have put on my battery ignition rowboat motors I can honestly say that
                    I have never drained one down to the point of it not running the motor.
                    I may charge it one or twice during the season for nothing more than reassurance.
                    Respectfully,
                    #85141
                      From what I understand, the buzz coil will draw down the battery
                      slower than an automotive type coil, so not sure how they compare
                      to a Evinrude RBM with coil, etc.
                      I’ll wait until I get the battery, and build a box big enough for the
                      buzz coil, and now that you got me thinking, perhaps two batteries!
                      Not sure I’ll need a lanyard for my Wisconsin RBM though, but
                      a toggle switch would be nice.
                      quote Tubs:
                      I made a box with 2 battery’s where I can switch from
                      one to another. The only time I thought I was getting
                      low on juice was running a Speedster and that was after
                      about 3 hrs. of running on a 4 year old battery. When
                      you consider how many times a Speedster fires the coil
                      per minuet as compared to an RBM you shouldn’t’ have
                      a problem -BUT- I wouldn’t go out without a full gas can
                      and a back up battery.
