Home › Forum › Ask A Member › automotive fuel line in outboard?
  • #324013
    kmead
      I need to replace some fuel line in my 1960 Evinrude Fisherman 5.5 HP. It appears to be 1/4” id, and I need about 40” total, and I wonder is automotive fuel hose good enough?
      #324032
        i have never used anything but  typical  “fuel line”   from NAPA ..
        #324036
        Matt Ignowski
          I’ve used automotive fuel line from autozone and or oreillys on many motors, and years later all are still just fine with no issues.
          #324046
          RICHARD A. WHITE
            The motor does not care if it uses automotive fuel line to sip its juice……
            classicomctools@gmail.com
            #324086
            Sam M.
              Also consider outer diameter so you can reuse the factory non-screw type hose clamps.
