Home › Forum › Ask A Member › Atom, Megafire, Nova2, kawim70114, or make it..
Viewing 5 posts - 21 through 25 (of 25 total)
  • #36176
    rudderless
      Ya, have been reading yours and others posts about the whole issue. I’ve made equivalent components and the thought of making a couple is interesting to me but..if its been done whats the point..
      \Now I have a question…why not use this simple system on all motors instead of using a separate pulse or trigger coil? I see most larger modern engines using the trigger coil setup so..
      #36203
      debe
        Ignition systems that use a trigger coil are CDI systems, totally different to point systems. Quite a lot of 2stroke engines have used the pointless ignition system with there own module, similar to the Atom module
        #36235
          I have several sets of Atom Modules here which I might never use.
          Should I auction them off on Greedybay to help bump up my pension plan? 😀
          rudderless
            Bigrichsoldoutboard hasn’t bit on the ebay one yet..cut him a deal!
            #36243
            wedgie
              quote rudderless:
              Trade for some grips? 😉
