Home › Forum › Ask A Member › Assesment of a ’55 15 hp Fastwin
- This topic has 4 replies, 3 voices, and was last updated 5 years, 10 months ago by
Don.
January 3, 2021 at 6:06 am #226834
I have had this engine taking up space on my rack for a few years now. Before even starting to look at it, I knew it was missing the cylinder head, the engine cover, the entire tiller handle and the throttle shaft between the tiller and the 90 degree gears for the vertical shaft. The two side supports for the recoil are also broken and have been half-bake repaired. I tore down the power head and found pretty bad cylinder scoring on number two; although the pistons themselves didn’t seem so bad, other than stuck rings. I also see that it has bronze wrist pin bearings which are maybe too loose. However, I also see that the wrist pins are too loose in the pistons. I can rock the rods back and forth and see movement of the wrist pins in the pistons. I guess this is going to be a parts motor, even for me, unless another ’55 comes along.
My main questions here are whether there is a way to measure the bronze bearings in the ends of the rods and is there a spec? It seems a shame to throw the rods away, as the big ends and the whole crank shaft, are completely rust free, even with the lower crank seal being completely missing. Also, am I looking for throttle shaft ball gears that are the more common smooth type or the earlier, kind of sharp-looking type? Thanks.
January 3, 2021 at 7:33 am #226862Book sez wrist pin clearance in con rod is 0.0007″ to 0.0014″ . I think you would have to look a long time to find one that isn’t way over 0.0014′
January 3, 2021 at 9:54 am #226886I guess there is little hope for this thing if you are not going to save it!
January 3, 2021 at 11:00 am #226887Well, not so fast…I just noticed that a spare, stuck power head that I have is a ’56, which has the same internals as the ’55 and it has the same head….I had thought that the spare was a ’57. This opens up whole new vistas…I can’t use the ’57 block, though, unless I want to change to the bigger recoil, which kind of defeats the coolness of the ’55. Why do I do this to myself?
January 3, 2021 at 2:44 pm #226907Wish I had parts/pieces for a 55 15hp, but don’t…. Still wanting to get your driveshaft and cover to you also, hopefully we can get together at Rocky Hill….Don
