Home › Forum › Ask A Member › Armature plate support grease
  • #267771
      While it is true that the mount is the ground return, it’s nothing to get paranoid about.  The high spark voltage has no problem jumping across any resistance.
      Like Frank says, this should not be an issue for the several thousand volts finding their way back to the coil.
      But, there is a ground wire on the little 2hp that is very important due to the plastic bushing on the mag plate that insulates the high voltage return.  There is a ground wire on everyone’s favorite “low tension system” as well.  On this engine, it is the primary lower voltage that returns to the mag plate.
      #267780
      bob-d
        Well since this post went from grease to grounds, I have another question.
        I noticed that OMC added a ground strap on the 33HP where my 64 28HP didn’t have one. Would it be a good idea to add it, and where exactly does it go?
        Thanks,
        Bob D
        IMG_2089
        #267796
          This was a real light bulb moment for me.
          • This reply was modified 4 years ago by Tubs.
          #267797
            Thanks,
            Bob D
            IMG_2089
            Since the motor is mounted in rubber mounts, the ground wire bonds it to the steering bracket.
            #267832
              Those are good reminders at a good time. Thanks, Don!
