Home › Forum › Ask A Member › AOMCI Members Only Forum
- This topic has 12 replies, 10 voices, and was last updated 5 months ago by
CHUCK.
April 8, 2025 at 9:16 pm #295258
Reminder to all Active AOMCI members,
Here is a link to the Members Only Forum in this area of our website. There are a variety of Topics discussed, with loads of information on Antique and classic outboard engines. To access you must be logged in with your active paid Membership Account. For anyone who is not a current member of AOMCI, this is one of the Benefits of being a paid member. Enjoy this great club and make the most out of it as you can.
Travis
VP Communications AOMCI
webmaster@aomci.org7 users thanked author for this post.
October 5, 2025 at 12:58 pm #300352Thanks Travis!!
Jeff R.
November 9, 2025 at 1:08 pm #301340I have a 1956 Johnson 7.5hp outboard that I would like to have inspected. I don’t have a proper workshop and tools, nor do I have the experience to restore this motor. It does run, and was tested in a barrel, but I think that the water pump may be worn. Is there anyone within 100 miles of Romney, WV who can restore this motor? I work on wooden boats, but not motors, but I can repaint the motor and add the proper decals. I will be restoring a 1949 Penn Yan Trailboat this spring, and this motor will be added to the boat, so there is no great hurry to finish the motor. I also have a 1960 Johnson 3hp and I would love to learn how to rebuild this motor. doug@dzaruba.com
November 22, 2025 at 9:36 pm #301761Doug, welcome to the club.
This post was accidentally made under the group site details page, rather than the actual forum.
Once you go to the “Ask a Member Forum,”
Scroll all the way to the bottom of the page, then put your post details in the box provided.
That will post it to the group where all of us members can see and respond to your post.
In regards to the 7.5 and 3 HP, they are very easy to work on. I am unfortunately on the East Coast, but there is a great following on the West.
Good place to start is by getting some manuals for them! Good luck with your search.
1952 Blue Streak "B-Stock Runabout" - 1952 Mercury KG7Q
1955 Feather Craft Vagabond - 1956 Mercury Mark 55EDecember 30, 2025 at 8:53 pm #302836Arriver today
Yonkers NY
March 6, 2026 at 12:28 pm #306410Anybody know offhand the socket size needed to take the flywheel nut off a 1993 Johnson 115 hp ? I know it is bigger than 1 1/4 inches as that is the largest I have. Thanks, Mightymite
March 6, 2026 at 6:42 pm #306575Anybody know offhand the socket size needed to take the flywheel nut off a 1993 Johnson 115 hp ? I know it is bigger than 1 1/4 inches as that is the largest I have. Thanks, Mightymite
Mightymite…..you inadvertantely posted in a Webmaster generated thread dated April 2025. I jut happened to see your post.
You will get better response if you start your own thread.
I think the answer to your question is 1 5/16 but post a new thread and see what others have to say.
March 12, 2026 at 5:50 pm #308802Thanks
May 24, 2026 at 1:42 am #319780Please forgive it this is wrongly placed. I have a1963 Scott McCullough Elgin 7.5 hp. low profile. Ive rebuilt the Tillotson carb.replaced the lower unit, replaced the recoil spring and srarter assembly. I put new old stock impellers in it, upper and lower, and made sure they were in the correctly. But on the very first trip out on my flat back canoe it got to hot. Hot enough that it shut down on me. But it didnt lock up. It was like it ran out of fuel. But, no dought, it got to hot. Now there is no compilations on nether cylinder. Ive put alot of time in to it, not to mention the money. Can someone please tell me what did i do wrong? And what would be some ways to fix it so it dont happen again? Thanku,Hot on the water, Nevada.
May 24, 2026 at 11:55 am #319834you inadvertantely posted in a Webmaster generated thread dated April 2025. I jut happened to see your post. You will get better response if you start your own thread.
There are a lot of reasons why outboards don’t cool even after a new impeller has been installed. a couple of common ones are: The water tube didn’t get inserted into the grommet at the water pump. There could be a blockage somewhere in the cooling system from broken pieces of an old impeller, corrosion, etc. Maybe the impeller key isn’t in the slot or maybe the impeller has spun on it’s center.
If you test run prior to going to the water you should be able to observe water exiting the exhaust relief or “telltale” if so equipped. You can use a digital thermometer to measure the temperature of the block during this test run.
