Home › Forum › Ask A Member › Anyone used double sided foam tape to pull dents on tanks?
  • #289608
    Monte NZ
      Hi All
      After reading club members methods of removing dents from aluminium outboard tanks, I was wondering if anyone has tried using the above?
      I have unsuccessfully tried hot glue and thought of this idea.
      Monte NZ
      #289609
        don’t know about tape  but  seen simple hot boiling water on  car dents allowing metal expansion and pop out of the dent.
        Of course not much would fix a  crease or crimp ..  Bondo and paint can fix them up.
        a local body shop may help.
        https://www.youtube.com/shorts/OKVPsa0g6qQ
        #289634
        aquasonic
          The car part in the video looks as though it may be made out of plastic.
          Improvise-Adapt-Overcome
          #289635
            I actually tried it on a kia Forte Koop  left back panel and….it worked about 70% leaving  the creased imperfection visible but it did work.
            . I suspect most side panels are metal.
            I did not want to tear into the rear inside panelling to push out the  metal panel  during the process  (helper would be required) but I feel confident it would have  pop back out with good results
            not my car so….
