Home › Forum › Ask A Member › Any tricks for removing flywheel keys?
  • #1084
    johnyrude200
      I recently acquired a motor that I found had a sheared flywheel key. Up until now, I haven’t had to replace many of these, but I have noticed in many cases the flywheel key is pretty well stuck inside the crank recess. Any tricks for getting these out without damaging the crank taper?
      #13180
        if it is a long one use a small punch and tap in and up from the bottom to loosen and grab with vice grips
        #13187
        DAN ANDERSON
          Im with Dave on the punch, but I grab the piece with side cutters (dykes down south) and lever it out against the crank. I use the same technique for pins, dowels, etc.
          Dan in TN
          #13191
          Doug Wilson
            would agree take a small punch and knock it until you can get it with side cuts
            Doug
            Doug
            turned off?
            #13208
            johnyrude200
              Worked great, thanks guys. I’m guessing the reason you strike the bottom of the woodruff key is to avoid accidentally missing the key with the punch, hitting the taper on the crank, and screwing things up….
