Home › Forum › Ask A Member › any tricks for leaky carb seats?
  • #2686
    jethrob
      I’m having trouble with getting a mid 70’s style 40 HP Mercury carb to quit leaking gas out of the carb. Tried multiple needles. I’ve been looking for a set of carbs for a couple of months and about to give up and junk the motor.
      Anyone have a trick for fixing the seat on a carb?
      #25011
      retiredoz
        Maybe your float’s not floating ?
        #25017
        Doug Wilson
          could be the float is too heavy and not floating or the seat the needle is going into is bad.
          Doug
          turned off?
          #25026
            did you set the float height correctly call me 1 914 310 7086.
            #25040
              The black, foam floats can get gas-logged and heavy, sometimes. New ones are hollow and white. Make sure the little spring is present, on top of the float, too.
              Also, if running in a tank, make sure it’s not tilted too far forward. Those side bowl Tillotsons can’t take a joke, that way.
              #25041
              mercuryman
                I use metal polish on Qtip to polish the seat.
