Home › Forum › Ask A Member › ANTIQUE OMC OUTBOARD IDENTIFICATION
  • #74871
    keplerfan
      here is a few pics
      keplerfan
        lower
        kees
          International Member
          thanks
          for sure, it’s the same as mine
          Lightweight model 401 ( on the ID plate 401 0718 )
          but what I wrote earlier, mine has the flywheel magneto.
          and …..with a closer look…. , lower unit is the same but prop and water pump are different ๐Ÿ™„ .
          #74984
          keplerfan
            does anybody know what kind of modern battery to use with this motor?
            #74985
              I use these 6V 4AH sealed Battery’s .
              Several brand’s to choose from.
              You can find them at a battery store
              if your not into eBay but the price
              could be quite a bit more.
              https://www.ebay.com/itm/Power-Sonic-6V … Sw3mpXKQpP
              #74991
                You can also stack four "D" cells in a length of PVC pipe. One end is glued on, the other threaded. Of course they are not rechargeable . . . ๐Ÿ˜Ž
                #74993
                Ron Devries
                  I guess a 4 AA holder with some rechargeable batteries would work too.
                  https://www.amazon.com/4AA-Battery-Hold … ery+holder
                  #74995
                    You have lots of options.
                    This is close to the style of battery that would
                    have been available when your motor was new.
                    https://www.ebay.com/itm/RAYOVAC-918-6V … SwpqRaxAp3
                    #74996
                      Double A batteries would not last very long – use 5 if rechargeable. . . ๐Ÿ˜‰
                      #75000
                      Ron Devries
                        quote Garry in Tampa:
                        NIMH rechargables are about 2AH each so 8AH total for the 4, the 6V Lead Acid battery recommended is only 4AH.
