Home › Forum › Ask A Member › Another new guy paint question
  • #270415
    14decoys
      A buddy brought me a 1940 johnson LT 10 and I need to know if the tank was painted originally? It appears that it was not to my old eyes. If not i am considering cutting the tank from the rear for dent removal and then polishing it. Never tried that before and may be biting off more than I can chew. Thanks for any help. Steve
      #270416
      14decoys
        Ill try laquer thinner on it but just thought someone might know
        #270417
        LLOYD LAUTNER
          Pretty sure the tank was painted dull aluminum under the decals. Does your tank still have it’s decals?  You will also surely need new leather primer seals and instructions to install them. If so,  contact me. I am the guy that makes them.
          #270418
          14decoys
            It does have the decals. I’ll check with lacquer thinner tomorrow and see if any paint comes off.
            #270434
            JOSEPH BRINCAT
              Gee, if it still has a good semblance of the original decals, some would suggest just cleaning and leaving it original… but your motor, your choice.
              #270436
                If the decal on you motor is original, to determine the
                finish on the tank when new, remove a small section
                with some paint stripper. The second example is a 1937
                Johnson LS. It would seem to indicate that the Johnson’s
                had polished tanks at this time. That may have changed
                by 1940. I suspect it was polished. If your motor still has
                its original decal, this test will answer your question.
                #270438
                14decoys
                  Thanks Tubs. After getting my hands on it I think there are so many dents that I am going to paint it. I appreciate all the replies
                  #270439
                  14decoys
                    It has what appears to be brass on the lower section. As I said, Im new to this. Do you use brass cleaner on this or is there something that works that you like?
