Home › Forum › Ask A Member › Another lauson twin coil question
  • #258447
    hondaatc
      Sorry guys i know this has been asked many times i think i might try the maytag twin coil on ebay .. anyone know if this is the one … picture attached thanks in advance
      James
      #258462
      CHUCK
        I wonder who the company is that makes these coils?  Anyone Know?
        Coils-are-Wound
        #258470
          In my search for an Eisemann coil for my ’37 Champion, the only sources I could still find for these Maytag coils are either Flywheel Supply or Mark’s Carburetor & Magneto Service (Maytag Mark).
          When I initially contacted Flywheel Supply directly, they wouldn’t sell me a coil when I told them I was needing it for an outboard motor.   In addition to Maytag coils, Flywheel Supply also has some Wico coils.
          Mark’s Carb & Magneto has a Facebook page but I don’t go there.   I ended up getting my coil thru Bob’s Small Engine Repair who happened to have one of Mark’s coils on hand.
          1982 Evinrude 25hp
          • This reply was modified 4 years, 6 months ago by Bob Wight.
          #258473
          Tom
            A while back, someone (Mas?) posted success using a John Deere Pony Coil in a Lauson Twin.  I can’t find the details, it might have been on the old board.
            Also, any chance you could stuff two of these on the original laminations?
            https://www.ebay.com/itm/262831814496?hash=item3d31ff3760:g:WHwAAOSwImRYk7EM
            A last resort would be to keep the original Lauson primary winding in place and mount a couple of OMC universal coils somewhere else on the motor.  Wire the three primary circuits in series and you might get lucky.  I’ve done this with one OMC coil and a Bendix Scintilla primary and it worked, but I’ve never tried two on the same primary.
            Tom
            • This reply was modified 4 years, 6 months ago by Tom.
            #258475
            hondaatc
              Yes the one i posted is from flywheel supply sold on ebay i think i might try one was just wondering if this is the one
              #258476
              JOSEPH BRINCAT
                I know that the John Deere pony motor coil will work in a Lauson, however the armature  laminations have to be cut down to fit the core… I think from 5/8 to 1/2 ” square. The coil on flea- bay appears to have the larger, proper size core.
                #258487
                lyks2tinkr
                  I did a coil swap in a lauson twin, not sure what model but the JD pony coil was a direct replacement.  No modifications required as I remember
