Home › Forum › Ask A Member › Amphenol pin tool
  • #19329
    legendre
      quote fleetwin:
      There are no “spring fingers” on the amphenol pins/sockets, they are just a friction fit into the rubber connectors.
      Amphenol made a number of connector styles, and there may also be some confusion / conflation with the Amp and Molex connector products.
      Common sense applies – irrespective of the manufacturer, the common style of connector with locking fingers / tabs on the contacts will generally use a service tool with a thin-walled tube that compresses the fingers which then allows the contact to be pushed back, out of the connector body.
      #19338
        I am not confused at all when it comes to the amphenol connectors used on the OMC outboards.
        #19360
        legendre
          quote fleetwin:
          No one suggested you were, why did you assume that was the case? If you say a 1994 Johnson connector doesn’t require a service tool, then that may well be the case – and no one said otherwise.
          As for my previous comment, I was referring to general confusion around connector manufacturers, types / styles and trademarks. AMP is frequently conflated with Amphenol (people assume "AMP" is a short form), just about any mated multi-pin connector has been called a "Molex" at one time or another, and so forth.
          #19371
            rjoynt:
            I won’t waste your time with this rant any further. Let me know if you have more questions about the ignition system on your 94 Johnson.
            rjoynt
              I found the 553-2700 tools at my local marine supplier. He said he will have it in a week or two. I am looking forward to getting it and having a new tool.
              Thanks for all of the responses.
