Home › Forum › Ask A Member › alternative replacement for OMC choke solenoid boot???? 303792
  • #272070
    outboardnut
      Since you guys are good at thinking out of the box—-
      I was wondering if anyone has thought of some kind of alternative other then purchasing a $40 dollar boot off of Evil Bay
      boott
      #272072
      Steve Martin
        What’s the OD of the solenoid?
        #272073
        MIKE SIMS
          Peter at nymarine has them.
          http://nymarine.ca/grommets.htm
          #272074
            any chance a  piece of large diameter heat shrink tubing could be adapted over the  solenoid…….  and over  a smaller  insert for the shaft.
            #303792  looks pretty good !  but with shipping and all …… cost may be back up to 40$   🙁
            • This reply was modified 3 years, 9 months ago by JACQUES.
            #272080
              How about an oiled, leather deer skin boot, fit to size as needed,
              and wired or clamped in place?
                How about just leaving it off?  OMC eventually did.
                #272114
                outboardnut
                  All interesting suggestions (as always)
                  Thank You
                  #272130
                    That’s what I was going to say. Especially in fresh water areas, leaving it off wouldn’t be a problem. A drop or two of oil would help.
