Home › Forum › Ask A Member › Also for Merc K series engines closed exhaust
  • #8244
    mikesea
      Hi Folk’s,
      Is there a good breathing closed exhaust system like I have seen made for the 20H that would fit KG4 or KG7?
      Thanks again,
      Mike
      P.S. Any books related to just the ‘K’ engines? I have the Harry Brinkman one which is very good for 4 cyl’s.
      #65004
      jw-in-dixie
        I use KG7, Mark 20 and 25 powerheads on K towers and all fit. Should be no problem.
        #65005
        mikesea
          JW Sir,
          Thank you so much for the information I can ad it to my wish list. Mark heads that opens a lot of doors.
          Mike
          #65006
            Get a howler tower if you want tuned exhaust
            #65036
            jw-in-dixie
              Mike, also use Merc 200 on a KE7 tower which is slightly shorter than the others, for more driveshaft engagement. Guess a 250 would be good also but, alas, I don’t have one. 🙁
              One thing you have to do when using non-K powerheads is to cover or cinch the swivel pin so that it doesn’t rise and disengage from the lower socket. That causes immediate erratic behavior relative to the steering. Don’t ask how I know that! 😮
              #65104
              mikesea
                Howler Tower? Thanks Jeff where do I look for one?
                #65105
                mikesea
                  JW I will watch out for that thanks you.
                  #65107
                    Howler towers were a dealer add on. Not many around now. What kind of a ride are you putting it on? They didn’t get that name being quiet. Take off exhaust covers & bolt on the new cast alum to mate to the tower, Then comes the expensive "Q" racing gearcase, $700, to have new gears, bearings, seals & shafts. If the gearcase is still rebuildable. Look for the "Foot Doctor" He has been at it for many years.
                    #65170
                    mikesea
                      Thanks again Jeff Foot Doctor ha perfect. Trying to keep a closed exhaust so I don’t get stopped for open exhaust. You know at dust with a nice flame out the pipes the non boat people might not really like it Ha
