Home › Forum › Ask A Member › Alcoa Propellers
- This topic has 10 replies, 7 voices, and was last updated 1 year, 3 months ago by
green-thumbs.
July 23, 2025 at 8:38 pm #298452
Does anyone know which brands might have used a propeller made by Alcoa? Or are they more of an aftermarket propeller company?
July 23, 2025 at 9:21 pm #298453I would be surprised to learn that ALCOA actual made propellors, more likely some manufacturer used ALCOA aluminum to make the props.
July 23, 2025 at 9:55 pm #298456July 23, 2025 at 10:45 pm #298462I thought that that propeller looked familiar, so I went out in the garage. Turns out my 1941 Waterwitch 571.35 air cooled 1 HP (earlier motors are 3/4 HP) has an Alcoa that looks almost exactly the same apart from a slightly wider blade tip in proportion to the area of the blades near the propeller (although that could have something to do with the picture), and no number marked on it. It appears that the rotation direction of that propeller is the opposite of mine, although that could have something to do with a picture flip somewhere along the conversion process from jpeg to image adress/url. Due to the size, I would guess that that propeller is also from a 3/4 HP Waterwitch. 1941 was the last year of the air cooled to my knowledge, so that would be an earlier air cooled if it is air cooled, or it could also be a water cooled engine, which would probably have been made before 1941 as well.
July 23, 2025 at 11:34 pm #298464The propeller came with a Frankenstein Neptune motor I was given, and I am fairly certain it does not belong on the motor. The motor’s shaft is designed for and has a 5/32 shear pin and the prop is designed for a 3/16 shear pin. I just wanted to know if this could have been a stock prop, but now I believe that sears motors used them. Thanks for the help, hopefully I can find the correct one.
July 23, 2025 at 11:37 pm #298465Alcoa did make propellers. The site below says around 1925.
July 24, 2025 at 6:43 am #298466July 24, 2025 at 10:17 am #298473The propeller came with a Frankenstein Neptune motor I was given, and I am fairly certain it does not belong on the motor. The motor’s shaft is designed for and has a 5/32 shear pin and the prop is designed for a 3/16 shear pin. I just wanted to know if this could have been a stock prop, but now I believe that sears motors used them. Thanks for the help, hopefully I can find the correct one.
I think Neptune would have made their own props, but I do agree with Tubs in that it is one of those propellers. That being said, it was probably used on both Sears and OMC motors of smaller horsepower.
July 24, 2025 at 11:27 am #298479That ALCOA logo seems to appear on various aluminum products. Perhaps ALCOA had an agreement with fabricators? Use our Aluminum ….put our Logo on it!
Maybe they got a better price if they agreed to that?
July 24, 2025 at 12:15 pm #298485That ALCOA logo seems to appear on various aluminum products. Perhaps ALCOA had an agreement with fabricators? Use our Aluminum ….put our Logo on it!
something along those lines would make sense, or there is also a possibility that they just produced a ton of small propellers and they were cheaper and easier to buy than to make in the factory.
