Home › Forum › Ask A Member › Airguide Tach
  • #3017
    fastjohn
      I have this pedestal mount Airguide tach. I want to use it with a Mercury Mark 58. It has four wires coming out of it. Two are for the internal light, the other two are red and green. After removing the back cover the red is labeled plus(+) and the green is labeled minus(-). Does this tach require a sending unit,or can it be wired direct to the motor? If direct, do they go to the mag and ground? If anyone is interested, I would be willing to trade this for the same tach in a surface mount.
        My guess is that it does require a sending unit.
        #27441
          This might help.
          #27458
          fastjohn
            I do not know the model number, and my tach is not on this chart(nothing is listed with 0-9000 RPM). After further research, I think it may be for an automotive application. If anyone has a vintage tach that will work on a Mercury four cylinder with a mag, I would be interested.
            #27459
              #27468
              theodore
                When I was a kid, I connected an Airguide tach to my 18 Evinrude. (-) went to the block, (+) went to one set of points. Used the selector switch for the proper pulses. Worked fine.
                #27503
                  #27545
                  theodore
                    I know he didn’t mention a selector switch, I did. And by the way, you did too.
                    #27687
                    rayr
                      I have a airguide 653B 0-6000 NOS flush mount with sending unit and instructions in original box. Let me know if you are interested
                      in it.
                      #27689
                      rayr
                        My mistake on tac, it is a surface mount which gets the B designation after model number.
