Home › Forum › Ask A Member › Aftermarket Coils for Lightwin RBM
- This topic has 11 replies, 5 voices, and was last updated 5 years, 1 month ago by
mercuryman.
October 5, 2021 at 3:46 pm #247774
I removed the flywheel and tank on the second 1925 Elto Lightwin, Model C,
to check out the coil, as long as the hotplate was still set up for heating tar
and melting wax.
I was surprised to see that the coil and wiring looks in great shape.
Only thing I can think of that it was replaced at one time.Did they sell aftermarket coils for these years ago?
It has a black casing, and no markings on it that I can find.The secondary seems okay a 5.5 K ohms.
I get inconsistent readings across the battery connection leads,
but perhaps that’s because the capacitor is “in play”?I was going to hook it up to a battery and check spark, but the timer
has to come apart first. The latch drive is turning very stiff like it
has petrified grease in it.Prepare to be boarded!
October 5, 2021 at 6:12 pm #247802There are videos somewhere about rebuilding these coils using new OMC coils and stuffing them in the case so they look original. Boathouse should know.
October 5, 2021 at 6:59 pm #247806
I believe Doug Penn and / or Art Decalb have
new replacement coils. Here are the coil rebuild
videos and one I did a long time ago on the timer.
I don’t have an explanation as to why your coil
is in such good condition,
https://youtu.be/xwbTlC1xIlA
https://youtu.be/e2vxDqF_OEU
https://youtu.be/zLS6IglCy9kA "Boathouse Repair" is one thats done without having tools or the skills to do it properly.
This reply was modified 5 years, 1 month ago by
Tubs.
October 5, 2021 at 7:41 pm #247813Tubs, I watched your video, and the Canadian Chapter Boy’s video before I fixed the first coil.
Very helpful, Thanks!I tested the good looking coil after supper, after freeing up the timer and cleaning the points.
It seems to spark good, so I guess I’ll leave it alone for now.Prepare to be boarded!
October 5, 2021 at 8:36 pm #247816
Mumbles mentioned them so I posted them more
for those who may not know there is a solution
for the rotten wire syndrome these coils suffer
from. I remember when there wasn’t a good
solution. I tried soaking them in gasoline, which
worked, but took several days and you ended
up with a container full of junk with no good
way to dispose of it. I ruined one tube trying heat
before I gave boiling them a try. First time I didn’t
let it cook long enough (wife came home unexpectedly)
and I ruined that coil trying to push it out. I was talking
to a member about how I had learned to get the coil
out but they weren’t always still good afterwards and
he suggested the Zephyr coil. Couple years after I did
the video the surplus military coil became available.
TubsA "Boathouse Repair" is one thats done without having tools or the skills to do it properly.
October 6, 2021 at 8:49 am #247837I always adjust those points by changing the shim under the contact screw. That’s the way Elto did it. Doing it the other way can get the points “out of square” very easily. I believe replacement coils from Elto were in a black case after some point in time.
October 6, 2021 at 9:55 am #247842I always adjust those points by changing the shim under the contact screw. That’s the way Elto did it. Doing it the other way can get the points “out of square” very easily. I believe replacement coils from Elto were in a black case after some point in time.
I had to add a couple of homemade brass shims to the first on I worked
on to bring it back to the .010 range, and it seems to work okay.I wonder how many years Elto / Evinrude offered replacement coils,
or any parts for that matter, for those motors.Prepare to be boarded!
October 6, 2021 at 12:24 pm #247843
[/color][/size]
October 6, 2021 at 12:54 pm #247846Good Tip Tubs. I had mine all apart and re-aligned the points
with movement on the slotted end. I didn’t think about or notice
mine being out of square.Prepare to be boarded!
October 6, 2021 at 2:18 pm #247848 -
