Home › Forum › Ask A Member › Advice on the condition of these gears
- This topic has 15 replies, 9 voices, and was last updated 10 years, 2 months ago by
chris-p.
August 8, 2016 at 4:34 pm #4944
Wondering whether these can be re-used.
Drive Dog
The cradle was rusted in place, so the surface where it sits is slightly rough/pitted.Forward Gear
Reverse Gear
August 8, 2016 at 5:06 pm #41762No way Gabriel, you’ll just have to scrap ’em.
August 8, 2016 at 5:06 pm #41763Paper weights….get another set…they are available…
classicomctools@gmail.comAugust 8, 2016 at 9:53 pm #41781Agreed, those are shot. Too much is gone on the gear teeth. I would place an ad here for a NOS gear set with a new clutch dog. Or, maybe someone has a good used set. Shouldn’t be hard to find.
August 8, 2016 at 10:55 pm #41787Put them up on ebay for sale as "slightly used" 🙂
Kidding aside, lots of guys should be able to help. What are they from?
August 9, 2016 at 12:57 am #41801Great example of TOO FAR Gone!
August 9, 2016 at 2:06 am #41811Okay I get it. You guys don’t have to rub it in 😉
quote Chris_P:Put them up on ebay for sale as “slightly used” 🙂Kidding aside, lots of guys should be able to help. What are they from?
They from my ’56 Johnson 10hp. I know you offered some parts to me a while back so I may contact you again if that’s okay. Although, now it seems like I practically need an entire gear case, which might end up being more cost effective.
August 9, 2016 at 11:57 am #41829quote Gabriel:They from my ’56 Johnson 10hp. I know you offered some parts to me a while back so I may contact you again if that’s okay. Although, now it seems like I practically need an entire gear case, which might end up being more cost effective.Those look like they’re from the smaller gear case, ’58 and up…I might have a set. You can email me at sdpiazza@aol.com and I’ll check in the meantime.
August 9, 2016 at 1:06 pm #41831I have a complete gear case for it call me 1 914 310 7086 Dave.
August 15, 2016 at 6:11 pm #42121So I picked up a complete gear case with new seals and a new impeller. Seller thought it was from a ’57 15hp which I don’t think exists, so I compared parts numbers for a 57′ 18hp and 56′ 15hp which all checked out fine.
Here it is.
Problem is I think there is some missing material.
Compared to mine.
The prop also seems damaged, and the hub seems off.
Compared to mine.
The props are definitely different pitches though, which I figured. (mine on the bottom)
Prop that came with it on.
My prop on. (The prop nut still fits on)
Any ideas what caused the damage and if its superficial? I didn’t take the prop off when I got it so I didn’t notice the damage. Seller said I could bring it back if I had any problems so not the end of the world. I could also swap all the parts over to my empty gear case.
