Home › Forum › Ask A Member › AD-11 link & sync question.
  • #6107
    david-bartlett
      I am putting this one back together after new coils, seals, etc and need to link/sync.
      My question is do I use the casting mark on the cam or another point. No visible marks that I can see.
      Thank you.
        try page 111 in the bible for oldies
        http://boatinfo.no/lib/johnson/manuals/ … on.html#/0
        #51038
          No mark scribed or cast on top of the cam?
          david-bartlett
            Crosbyman,
            I have that manual, but this cam is different. No line in it like others. Gotta do some more digging.
            Thanks, David
            #51040
            david-bartlett
              quote Mumbles:
              Jim,
              No marks that I can see. These 7.5’s are a different cat all around.
              david-bartlett
                In the pic with the pencil you can see the casting mark and the pencil is pointing at a "possible" mark, or it could be a casting flaw.
                #51088
                david-bartlett
                  Well for now I put the cam back on and used the mark I pointed at with the pencil. This will get things close enough to run and I can tweak it more in the Spring.
                  #51092
                    My 7’5’s are put away but I’m sure I have a box of parts in the garage. There has to be a mag plate in it so I’ll bundle up and look around around for it later.
                    #51098
                    rpsiii
                      Hi David!
                      I checked out my AD 10 and my Evinrude Fleetwin 7.5 and both have a clearly cast in "mark" in
                      exactly the same place on the cam as you show with the pencil point. I guess yours was just not
                      "marked" well when it was cast. My throttle follower makes first contact at that point as it
                      should so I think you would be correct in using your "fuzzy" mark as you have.
                      C’mon Spring!!
                      Bob S
                      #51099
                      wedgie
                        Here’s my AD 11 that I just winterized halfway through winter. 😳
