Home › Forum › Ask A Member › Ad 11 Johnson
Viewing 10 posts - 1 through 10 (of 24 total)
  • #276843
    Donald Keller
      I picked up an Ad 11 Johnson…It has fire both cylinders…Rebuilt carburetor…It runs like a minute dies…after it sets a little bit..It will start back an does the same thing again..I put a different carb on it ..It still does same thing…The fuel tank I am using is good..use it all the time on other motors…I set the low an high speed 1 an half turns an 3/ 4 on other…It sounds good while running..Any ideas an help would be greatly appreciated..thank you
      Donald Keller
      #276846
        did you do  all the electricals…              did you vent the tank  ?               does is get to hot to touch   ?     is the water pump working ?
        does it keep running  if you pump the fuel primer  button  on the tank   before it dies on you ??
        did you clean the  glass bowl filter element under the carb … ??     drill a few holes in it if to plugged up to clean
        does the hose connector to engine leak fuel when you pump the primer
        #276850
        Donald Keller
          Only electrical work I done, was clean points an new plugs.It has fire..I rebuilt one carb, and then put a different carb on it, both will run a minute an quit..I cleaned fuel bowl.connection for fuel line isn’t leaking,,, the preasure tank that I am using works good on other motors,,I have even used two different preasure tanks..Could the coils or condenser be dropping out..It’s got me..It just seems like it running out of fuel?
          <!–more–>
          #276851
          Donald Keller
            I also put new fuel lines on it to carb
            #276852
            Donald Keller
              It is pumping plenty of water also..is not getting hot
              #276853
              Donald Keller
                I also tried pumping primer button on tank…and it still quits,I even tried to pull choke half way,,still dies…
                #276859
                LLOYD LAUTNER
                  Bad condensers will do that.
                  #276861
                    see picture of problem areas  if coils original  they are likely cracked….best to redo all the electricals but   try condensers first has suggested
                    #276863
                    Donald Keller
                      Ok…thakyou….Crosbyman…I will replace condemsers…an check points  again…if that don’t work..I will replace coils…I will get back with you once I get it changed out..to let you know which one it was…thank you  again for the help..I appreciate it
                      #276872
