Home › Forum › Ask A Member › AD-10 Exhaust Plate Assembly
  • #6208
    drifter
      I have a new gasket (202580) and good baffle plate (203020) and good exhaust cover (203374).
      I believe the sequence of parts installation is: gasket, followed by plate, followed by cover.
      So, no gasket between cover and baffle plate.
      Since there is no gasket between the plate and cover, should any kind of sealant be used?
      There is a brown varnish like substance on the outside (cover side) of the pate. What is this and why is it there?
      Thanks,
      Nick
      #51930
      david-bartlett
        Correct on the sequence. As to the brown stuff, probably gasket cement was used before.
        #51932
          Use some sealer, such as 847 for the metal to metal joint. But nobody is going to come get you and toss you in the slammer if you put a gasket in there.
          #51935
          drifter
            Frank, at my age I can’t risk the potential slammer so a gasket it is.
            Thanks,
            Nick
            #51947
              I personally put a gasket in there.
              #51950
              DAN ANDERSON
                Me three. Just did one & put a gasket because I didnt even look. Just thought one went on both sides. What were they thinking? Just bought some more gaskets off Ebay for another one Im going to do. At $3.00 per gasket I wouldn’t even think about it.
                Dan in TN
                #51960
                wedgie
                  Me four . Can’t hurt,It can only help.
                  #51962
                    I’ll go with the flow. Me five!
                    Two gaskets. Always!
                    #51986
                      Now you guys tell me about the gasket 😄
                      I just put the cover back on my 7.5 Fleetwin
                      yesterday. I was wondering why there was
                      no gasket when I took it apart, but it only
                      showed "one" gasket on the parts diagram,
                      so I just gooped it up, lol.
                      wedgie
                        There was only one gasket back in the day, so you should be fine.
