Home › Forum › Ask A Member › A25 Two questions
  • #2340
    GARY
      (1)My chart shows Echlins JP232 as the recommended condenser,but I have been unable to find one at local parts stores.Suggestions? (2)What screws need to be taken out to grease lower unit?
      #22581
        Your original cap had a rating of .12 uF so a Vishay axial or Orange Drop cap with correct voltage rating will work quite well if you can’t find a can type replacement.
        #22582
        Goman
          3 oz. of grease filled from the side screw on the gearcase. I believe the other screws are for gear tension adjustment.
