Home › Forum › Ask A Member › A special Milemaster Pressure Tank??
Viewing 10 posts - 11 through 20 (of 23 total)
  • #209424
    JOSEPH BRINCAT
      Yes, what mas said.. A reserve fuel tank. Many ( all ?) the British motor cycles had a reserve system incorporated in their fuel tanks. These worked with a three position petcock, closed, open to primary fuel volume and third position for reserve.
      #209475
      mas
        OK…case closed. The reservoir is an “oil measuring/mixing” reservoir.
        Watch the video…sorry I’m not a professional film producer!
        MileMaster Prototype Video…click this link
        • This reply was modified 6 years, 3 months ago by mas.
        #209478
          Watched the youtube video, definitely seems to be a reservoir for measuring an exact quart of oil…. Very ingenious… But, this just seems like a lot of engineering and expense with not much benefit….Didn’t outboard oil come in quart containers back then? Why design all this when you could just dump the quart container of outboard oil into the tank….
          Very cool nonetheless…
          #209495
            Very interesting, but as Fleetwin says “Why”. Quart bottles and cans of oil have been
            around a very long time.
            Ace-bottle
            mas
              Quarts, yes! Maybe that’s why it never made huge production. But, they made gallons too. I just do not believe it was home-brewed.
              #209680
              mas
                I have one of the earlier flat top three piece tanks that has baffles. This tank has rounded shoulders and baffles so I wonder it was one of the earliest of that type produced? Sort of a hybrid.
                I can’t figure out the two sealed screws in the bottom though. Maybe pinhole repairs, but the condition of the tank looks good. It’s hard to imagine that’s from the factory. It doesn’t seem like screw holes in the bottom of a fuel tank makes sense. Hopefully someone can shed some light on this.
                Hey Aquasonic…any chance of posting pics of those baffles? I would like to see the variations in tank designs for these pressure tanks.
                Thanks if you can,
                Mas
                #209770
                  OK – you figured it out without the instruction manual. It was an after markret device for those who wanted to “top off” a six gallon tank that still had some gas in it. The volume of the device is 1/24 of the tank volume – one quart. To top off a partially filled tank you closed the port and put in oil to the “Full” mark, Then opened the port and added the gas to the “Full” mark. Shaking the can vigorously resulted in a perfect 24 to 1 mixture. They were kind of expensive, but still less tan a new tank. You were assured you could always eave the dock with a full tank of perfectly mixed fuel.
                  #209780
                    OK, I get it now… There will be some premix in that cannister when the tank is partially full. Simply close the valve, fill the partially filled cannister with oil, then open it and add fuel. Always the right mix….Cool!
                    #209789
                    mas
                      Thank you for the info Garry. You provided more than was in my small brain. The part about a mixing partial tank is where the tank has its advantages.
                      Are they more common on the east coast or mid-west? I have never seen one around in the west. Anybody have any literature?
                      Happy Boating,
                      Mas
                      #209801
                        It was build by another company but endorsed by OMC. I no longer have the service bulletin that gave the information. I recall it came out around 1953 or ’54 . . .
