Home › Forum › Ask A Member › A real life Johhnyrude!!
  • #57360
    63lstrition
      Any thoughts on how I should approach the two ’57 35 hp?
      #57365
      chinewalker
        Thanks Ben! It’s actually one of my favorite motors. It lives in the boathouse and is usually the first motor I get out in the spring and the last one to get put away in the fall. It’s my workhorse!
        – Scott
        #57366
        chinewalker
          quote 63LSTriton:
          Take the best of both motors and make one good one! They are part for part identical. If having serial numbers match is important to you, you can swap the swivel brackets as needed, too.
          #57468
          johnyrude200
            Out of right field…nice motor stand… 😀
            #57483
            63lstrition
              I love that stand too. Not only what is on it! I got it for $40 when a local marina shut down. It had pipes welding on the other side to hold about 10 – 12 Mercruiser outdrives. I cut them all off, and it fits outboards perfect and is easy to roll around the garage on its big wheels.
              It has a fair amount of weight on it – ’77 Merc 1500, a pair of ’57 Big Twin 35 hp, a ’49 Merc KE-7, and a ’64 Merc 110. Hard to see, but there is a parts OMC V-4 85 hp sitting on the lower platform as ballast. Probably well over a thousand pounds
              #57593
              63lstrition
                Here’s another example of a Johnyrude-https://appleton.craigslist.org/bpo/6123593243.html
                #57601
                  That one’s mostly Johnson except for the starter handle and the ‘wanna be Merc’ black paint!.
                  CHUCK
                    quote Garry in Tampa:
                    I have MacX Utube Downloader and MacX DVD Video Converter to do that. Stick them on a thumb drive and watch them anywhere. . .
                    Garry have you actually figured out a way to download those manuals all at once?
                    #57711
                      I have more folders and programs than I really know what to do with them . . . 🙄
