Home › Forum › Ask A Member › A question about JW/Lightwin starters
- This topic has 6 replies, 3 voices, and was last updated 4 years ago by
Leon.
August 28, 2022 at 2:14 am #265059
How many other OMC outboard motors have the same diameter starter pulley as the older 3hp outboards?
I am doing a retro fit on an
HD-20 and I am in search of a pulley, spindle and pawl ring.
This is the older style 3 pawl assembly.
August 28, 2022 at 7:57 am #265061I have this
August 29, 2022 at 5:45 pm #265222So, today, I found a 1957 Evinrude Lightwin 3022 on Craigslist for $25 and I jumped on it. It has the later elliptical style hand starter assembly, but nevertheless I got a complete motor with two new mags in it.
Hopefully, I will still be able to find an earlier style pullrope pulley close to that price. I found a pawl ring and it’s on it’s way here. Now I just need a pulley, rope and center spindle and I should be good to go.
August 30, 2022 at 5:19 am #265267I’m not exactly sure what you’re trying to do; but if it helps, I recently found myself with Lightwin starters coming out of my ears. I would be glad to send you one for the cost of shipping, if that’s what you need. The only catch is that they are in the basement of a house I rent to some germaphobes, and so I won’t be able to get to them until after they leave for the season, in mid-September.
September 1, 2022 at 9:23 pm #265422Yea that will be great. I’m in no hurry as I’m doing outside projects right now.
If you have one with the 3 pawl set up, that is what I need. It looks like those would be on the ’55 and older on JW and Lightwin. I believe in ’56, they went to the single plastic eliptical pawl. My newly acquired ’57 Lightwin is the later style.
September 2, 2022 at 5:32 am #265435Would what you need be the same as a TD 20? I know the housing would be bigger but the pulley might be the same. I’m pretty sure I have a TD 20 but also pretty sure my Lightwin ones are all single pawl. I guess I won’t know for sure until I look.
November 1, 2022 at 10:13 pm #268573it looks like ’55 and older JW/Lightwin is the only thing that will work on it. ’56 and later has the single elliptical pawl and I need the older 3 pawl system. the 1954-’55 5.5 CD pulley will likely work.
