Home › Forum › Ask A Member › A few more unknowns. With No part numbers.
  • #260352
    Beno
      Going thru the bins. Some of these have no identities?   One has the red plug system.   The timing plate looks familiar? Mercury?
      The stator looks on great shape but only the plug seems to be any identification?
      #260357
        mag plate is mercury auto tranny motors
        #260361
          I’m going to go a little later model Merc 200, full gear shift. I was thinking auto-tranny too; but the thing that doesn’t figure is the spark plug wire shield. Also, auto trannys had a solid, full mag plate. I was surprised to see that drag link system on later engines!
          https://www.marineengine.com/parts/mercury-outboard-parts/200/1558310-thru-1866495/flywheel-assembly-and-throttle-control-linkage
          #260362
            As for the first two, I think that’s going to be from a late 80’s OMC three cylinder, probably the same one as where the VRO pump came from? Fleetwin will know for sure.
            #260363
              3rd one is 3 cylinder Merc but that doesn’t help much. I can’t seem to figure out which one.
