Home › Forum › Ask A Member › Substitute for OMC Shift O-ring #301877, Sierra 18-7100
Viewing 11 post (of 11 total)
  • #292065
    LARRY CATON
      The Mercury shift-rod o-ring #25-85594, passed the pressure test with flying colors.
      My homemade test device leaked where I screwed it into the gearcase oil overflow, probably because I didn’t want to waste a proper plug washer/gasket.
      I repeatedly tested with soapy water applied to all seals and screws at 7-10 psi.  I also vacuum tested.
      Lastly, I submerged the unit in water. The gage needle didn’t budge, and no air bubbles emerged even when I repeatedly moved the shift rod up and down.
      I’m calling it a win.
      1956 Johnson 15 Hp, FD-10
      1957 Johnson 5.5 Hp, CD-14
      1958 Johnson 5.5 Hp, CD-15
